error 6 occurred at invoke node in dist build app
Error 6 occurred at Invoke Node in Dist Build App from LLB.vi->Dist Build App Image.vi->Build Application.vi
Possible reasons:
LabView: Generic file I/O error
or
NI-488: I/O operation aborted
Version 6.0.2
(3,103 Views)
I noticed that you updated your system to 6.0.2. A couple things to check on that may remedy the problem.
1)Did you install the application builder after upgrading your system to 6.0.2? You will want to install the application builder 6.0 first, and then add the 6.0.2 update to the whole system.
2)Have you mass compiled all of your VIs since the upgrade? You will want to make sure that all of your VIs are in 6.0.2 format before trying to build them into an executable.
Matt Kisler
(3,103 Views)
We have the professional development system which means the app builder is in the system install. All vi's have been mass compiled.
Karen Eliason
Manufacturing Software Applications Technician
Detector Electronics
(3,103 Views)
We reset the builder to include an exe file extension in the application name and the vi now builds.
(3,103 Views)
