error 42 at init serial port
I built a simple application  using LabView 7.1  using serial ports and using VISA . I finish the project and built the installer. on the development PC I test the application (from the "start" menu,  and it run correctly. when I try to insall it at another PC (after  checking  that the appropirate port is valid)
I have got an error message "Error 42 occured at Init Serial Port"
what could be the reason for this problem
Haim
(3,271 Views)
I am using 7.0 but have never used 7.1. But check out this setting. It may help
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,261 Views)
Hi there
Have you installed VISA on the target system? You can download it here: https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html
Make sure to enable the "serial port support" option at the Advanced installer settings tab page.
Message Edited by chrisger on 01-01-2009 09:41 AM
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,227 Views)
