07-16-2019 04:47 PM
I am trying to set up a program that will send a text message using the SMTP protocol. I already made it work before, but for some reason it is giving me the error 363513. I have tried changing the port number but it does not work (the one I'm currently using is 587). I am thinking it could be related to the flow of data, but I am not 100% sure what could be the issue. I have this VI feeding other VIs, but the code for SMTP text message is the one inside the red box. I'm also attaching a screencap of the error that pops up everytime I run the program.
LabVIEWSMTPClient.lvlib:Send.vi:2280011<APPEND>
<b>Complete call chain:</b>
Thank you!
07-17-2019 03:01 PM
What did you change in your program between the working state and the non working state which you are in now?
07-19-2019 02:46 PM
Did not change anything, I'm not sure why is it having trouble. I tried to put the text SMTP code into a subVI and it worked once, but then stopped working again. When i try to probe to see the error it comes from the Send Message.vi (LabVIEWSMTPClient.lvlib:Send.vi:2280011) - The error starts there and it is just showing as an error coming out of that VI.
