‎08-31-2006 02:43 PM
‎09-06-2006 02:19 PM
Hi Tom,
What hardware are you using inside the chassis? I am using it is National Instruments scope card. What is the program trying to do?
Usually this happens if an acquisition is not aborted before starting another session. What is surprising is it's intermittent behaviour?
Do you also have PCI version of the scope with which you are testing the program with?
Can you please post some more information as what hardware you are using, sample code which can replicate the problem, driver version?
Kalyan
‎09-06-2006 09:39 PM
‎09-07-2006 07:00 PM
Hi Tom,
I am looking for information on the data acquisition card and the driver/software you are using to communicate with the card.
"Right now the program is in a loop so if the data acquisition returns an error, it will require the data. Although it works, this is not the fix I am looking for."
Are you mentioning that the card acquires data even with error? Please post a sample code or screenshot of the error. Screenshot information might help to debug the issue.
Kalyan
