07-13-2021 10:28 PM
Dear ALL,
I am using sbrio-9628 CAN port. The API is embedded CAN for sbrio.
and I follow this Knowledge base.https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000wzGpCAI&l=zh-CN
I have tried to install the driver many times, but still gave the following error.
Labview version : 2020
compactRIO version: 20.5
07-14-2021 12:43 AM
Hi kisyou,
Did you also install that driver on your sbRIO (using MAX)?
07-14-2021 01:45 AM
Of course, I installed the driver on sbrio. And tried different installation methods (mirror installation, traditional installation method).
07-14-2021 01:54 AM
you can check the software list in sbrio.
07-14-2021 02:12 AM
Hi kisyou,
According to all the documents in your own link (in message #1) your sbRIO9628 is not supported for EmbeddedCAN! (See here, here, or here.)
Why do you try to use EmbeddedCAN anyway?
Instead your device is listed for "NI-CompactRIO: sbRIO with DAQmx" and explicitely mentioned in this manual!
The sbRIO9628 is also listed in the NI-XNet compatibility list: you can use the XNet API as well!
So even though you linked the correct KnowledgeBase article it seems you didn't read it…
07-14-2021 02:22 AM
Using the RMC card and NI-9628. also it's a solution.
But in the compact rio 20.5 readme. it says "The "CAN api" means Xnet? "
07-14-2021 02:34 AM
Hi kisyou,
I'm not sure, but it is not EmbeddedCAN!
In one of the documents listed in my previous message NI mentions to use FPGA IO nodes as you would do for a NI985x module on cRIO…
07-14-2021 02:37 AM
ok , anyway thanks for your comment.
I will send email to local NI engineer.
