dynamically launch selected VI on cFP target
I am running LabVIEW 2011SP1 on a Win7 machine. My applicatoin uses cFP to monitor temperatures, and control 6 heaters (PID feedback) during heating and soak segments of a profile. Cooling segments are passive, no control aspects, I need only monitor temperatures until some setpoint is reached, then another segment of heating and soaking. I have the heating segment coded, passing setpoints via networked shared variables to the cFP controller (cFP2200). My thinking is to write a second VI to monitor thte passive cooling phases, but then I need to be able to toggle back and forth between two VIs on the target. Is this the correct approach (and if so how do I do it)? Or would it be better to make one huge VI to handle both scenarios?
TIA
lmd2
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(1,919 Views)
Accepted by topic author lmd2
Do you have to toggle between them or would you be able to run them in parallel with each other?
Based on what you described, I would suggest writing a main VI to control the VI you've already written along with the new passive monitoring VI as subVI's.
CLD Certified
(1,901 Views)
Thanks, got a similar suggestion from someone and wrote a shell that uses a state machine for monitor / control. Thanks for the response
cell: 516.819.9711
(1,897 Views)
