dynamically control the frequency of input signal
Hi all,
I am creating a program which can generate a signal while I can control the frequency dynamically (don't need to stop). I have idea about creating a while loop around the waveform I generate, keep checking if the output frequency is same to the input frequency. If yes, it runs and if no it will update the value automatically. However, I found no where to start. I started learning how to use LabVIEW only several days ago and I will be really grateful if someone give me some hints.
Here is my file.
(1,133 Views)
Accepted by topic author ANDREWSMLX
By the way, I used DAQmx and my input NI device is NI 9263
(1,132 Views)
