02-02-2010 09:25 AM
I am trying to output two channels simultaneously in the following manner. One channel will be a constant frequency and constant amplitude sine wave that is based the continuous generation waveform provided by NI. The other channel will be a time-linear frequecy sweep, whose amplitude remains constant, but whoes frequency changes as a function of time.
I have both these VIs working independently, but when I try to comping them, I get stuck. I have read numerous posts on dual channel output, and tried many of their suggestions, but the posts that do work deal with constant frequency dual channels outputs, or, I do not konw enough about DAQmx timing to make the system work. Any suggestions are greatly welcome. I've attached the inidividual VI's below.
Thanks!
02-04-2010 10:37 AM
