10-05-2011 11:48 AM
I am trying to get a dt 9834 to work with labview for data analysis. I ran the example that came with the data translation board but I cannot get the rates required by the test. I know this is not a dt website but any help would be appreciated. I need 50k samples per second over 11 channels on data in. Any ideas on how to speed up the acq speed.
10-05-2011 12:41 PM
DT 9834 has throughput of 500k Samples/s, that means for 11 channels you can't exceed the data rate of 45.45kS/s. You can get higher data rates using less number of channels or using an additional module.
10-05-2011 02:22 PM
That's what I was trying to tell the engineer!!!!!!!!!!!!!Thank you for the response now they should believe me!!!!!!!!!!
