dsc can't creare the Application (EXE) with Open Trace.vi.
Hi all
I work with DSC.
I can't creare the Application (EXE) with Open Trace.vi.
Best regards
Iskander
Message 1 of 8
(2,915 Views)
What's the error message when you try to create the exe?
Paolo
Message 2 of 8
(2,913 Views)
Hi Paolo
I solved this problem.
If I changed my Project I can't do Application.
If I save project, close its and then open this Project I can do Application.
Best regards
Iskander
Message 3 of 8
(2,891 Views)
Hi Paolo
My problem  persists
My VI is working
But when I do EXE I receive the ERROR:
Error 1003 occurred at AB_Targetfile.lvclass:Open_Top_Level_VIs.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller.
What can I do?
Best regards
Iskander
Message 4 of 8
(2,851 Views)
Hi Iskander,
What version of LabVIEW are you using?  This is a known issue that was fixed in 8.2.  The issue has been shown to happen when building a VI that includes a subVI containing a shared variable.
If you are using a version of LabVIEW earlier than 8.2, the best solution is to upgrade.
If upgrading isn't an option for you, here are some potential work arounds:
1.  Check the Enable debugging option in the Advanced category of the application executable properties
2.  Disable the Remove Panel option for all SubVIs containing Shared Variables in the build
3.  Uncheck the Disconnect type definitions and remove unused polymorphic VI instances option, also in the Advanced category of the executable properties as shown below
4.  Move shared variables to the top level VIs and pass the data through the SubVI connector
I hope this helps!
Dayna P
Notes for Branch AE:
Please reply to This Post within 24 hours
The US AE is expected to reply to all of your posts within 24 hours. Having this expectation will keep the escalation moving quickly and toward a fast resolution.
You can also use other communication channels: Phone, Skype, etc. to discuss the issue with the US AE. This can help with troubleshooting and quick diagnosis of the issue.
Click here to provide kudos for a post on this page
Message 5 of 8
(2,829 Views)
Hi Dayna P.
I am using LV 2011
My project has shared variables.
Best regards
Iskander
Message 6 of 8
(2,824 Views)
Hi Iskader,
It turns out that this is a known issue for LabVIEW 2011 (CAR# 306205).  It was fixed in LabVIEW 2012 32 bit.  There is a workaround explained in the LabVIEW 2011 Known Issues Page.
I apologize for the inconvenience caused by this issue.  I hope this helps!
Dayna P
Message 7 of 8
(2,792 Views)
Hi Dayna P
Thanks for the help
Best regards
Iskander
Message 8 of 8
(2,767 Views)
