12-19-2011 02:03 AM
Hi Julianne K
Thanks for the help and attention.
I run Yours Project.
I have the delay 800-1200 mSec.
I have the new PC.
Where is my ERROR ?
Best regards
Iskander
12-19-2011 06:29 PM
Hi Iskander,
Do you have many shared variables in your Distributed System Manager (how many)? If so, try to undeploy them so that only the variables of interest are deployed. Dpes this increase the speed of the read? Also, try disabling your firewall and antivirus software to ensure that it is not interfering.
Also, there are other methods to set alarms programmatically. Have you tried using the Set User Defined Alarm subvi as an alternative solution?
12-22-2011 01:24 AM
Hi Julianne K
I run only Yous project Iskader.zip.
Delay is 800-1200 mSec
The firewall I have not and antivirus software (ESET NOD32) was disabled.
The delay remained unchanged 800-1000.
The System Idle Process is 98 %.
I don't know what can I do?
Respect
Iskander.
12-26-2011 01:53 AM
Hi Julianne K
What is requirement for the PC and OS? My PC has Windows XP 32 bit.
Regards
Iskander.
12-28-2011 10:28 AM
Hey Iskander
Your computer stats are well within the operating requirements for LabVIEW, so I doubt that is the root of your timing problem.
12-29-2011 03:21 AM
Hi all
Happy New 2012 Year.
Thanks for the help.
But my problem don't solved.
And I don't know what do I do?
respect.
Iskander
12-29-2011 09:14 AM
Hi Iskander,
I would like to follow up on earlier suggestions. How many shared variables do you currently have deployed in Distributed System Manager (DSM)? You can access DSM by going to your Start Menu -> National Instruments -> Distrubuted System Manager. This is where you can view the number of shared variables currently deployed on your system.
Also, have you tried using the Set User Defined Alarm subvi as an alternative solution?
01-16-2012 01:38 AM
Hi Julianne K
I ran the DSM
I have all near 120 shared variables now.
I didn't try use the Set User Defined Alarm subvi.
I ran Yours project on another PC . The delay was the same - 700-1000 ms
I must to solve this problem.
I can to permission Yours the remote access to my PC that You can see this delay.
Respect
Iskander
01-16-2012 03:04 PM
Hi Iskander,
I do not think that remote access to your computer will help, as I can see from your earlier screenshots that the delay exists. Please try using the Set User Defined Alarm method. An example to get started with is the DSC Alarms Demo/lvproj, which can be found in the Example finder. A good VI which is located in this project is "DSC User Defined Alarms Demo.vi." Please let me know if this method solves the problem.
01-24-2012 02:11 AM
I know about the Set User Defined Alarm method.
You wrote that the delay for Yours example Iskander.zip 17 KB is 100 ms
Did You use Set User Defined Alarm method in Yours example?
Best regards.
Iskander
