Hi pasolo,
I'm not familiar with the TJA1010, so I'm assuming for this post that you have already hooked up one of the digital lines from your DAQ card to the input on the motor driver.
From what you describe, it sounds like you want to do a specific pattern generation on an external clock. There is actually a great example for that in the NI Example Finder. Just open LabVIEW and go to Help >> Find Examples. From the Browse tab, go to Hardware Input and Output >> DAQmx >> Digital Generation >> Cont Write Dig Port-Ext Clk. This should allow you to write a pattern of 0s and 1s that correspond to your required waveform. Also, some of the other examples in there might be helpful to look at as well.
I hope this helps!
Justin M.
