download package for Labview NXG not running on windows 7 32bit
i want to download trail version of labview Nxg, when download first its package download which is not exutable in windows 7 32bit,
please see attached file..
(2,894 Views)
LabVIEW NXG is 64 bit only and therefore only can run on 64 bit Windows.
Rolf Kalbermatter
My Blog
(2,873 Views)
thanks,
but atleast it should down load on 32bit windows, how can i download on 32bit?
Asif Iqbal
(2,846 Views)
Looks like you're trying to run it, not save it.
Bill
CLD
(Mid-Level minion.)
(2,840 Views)
Accepted by topic author Asif138
Hi Asif138,
I want to reinforce what Rolf said in his post - NI Package Manager (used to download and install LabVIEW NXG) is a 64-bit application, as is LabVIEW NXG and will not install successfully on a 32-bit system.  It sounds like your use case is a little different - just attempting to download the installer on 32-bit.
What exactly are you trying to do with the downloaded 64-bit application on your 32-bit computer?  We might be able to help you out with this, but we need a better idea of what your end goal is.
Matt | NI Systems Engineering
(2,813 Views)
You did download it, if you hadn't then there'd be nothing to run to generate the error message you showed.
(2,809 Views)
