09-16-2009 02:08 AM
09-16-2009 02:26 AM
09-16-2009 11:08 AM
Oh I was typing my query in a notepad & forgot to paste it. Sorry!
So here i am trying to pass two data streams from host to target FPGA through FIFOs. I want to process these data streams on FPGA & write the output in another FIFO & give it back to the host. I have made a simple model for it. Forgive my ignorance but i dont understand the behaviour of the program when i set Count ( Loop Timer) to a low value like 20 ticks. What is actually happening when i want the FPGA VI loop to run faster? What I can i do to make sure that no output data is lost? Secondly are there any other constraints while using multiple FIFOs?
I am using PXI-7842R & LabVIEW 8.6.1
09-17-2009 02:41 AM
10-09-2009 02:23 AM - edited 10-09-2009 02:25 AM
10-21-2009 05:42 AM
10-22-2009 03:13 PM
Have you seen the Host synchronization examples for cRIO? You could implement triggers to ensure that the host and FPGA FIFOs are timed properly.
THanks,
