These are all options that are selectable when you save the vi's. You want to make a copy of all your work before you do it, to make sure that you don't lock yourself out of your code. If you right click on the vi's icon you will get a menu allowing you to go into the properties. You can save vi's without diagrams, or you can password protect them, to allow certain customers/users access as you see fit. I haven't tried the front panel scale to fit option in a long time, it had problems in the past with scaling certain front panel objects.
PutnamCertified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
