displaying on the front panel from SUb vi
Open rcvAOMsgLoop and SENDAODATA. Start the former, then the later.  You should see changes to the log_data in the AO SCP DATA and changes to the telescope ID in the TCS.
Now stop them.  Start sendrec and then SENDAODATA.  Why don't the clusters update.
(2,848 Views)
Hi exo,
maybe you should attach more than just an empty library?Smiley Wink
(2,841 Views)
It would be nice if I could figure out how to use the LLB manager or if the help was more helpful. You would think that a button that says make a LLB did more than make an empty library when you are looking at the list of vi's you want in the library.
(2,836 Views)
  1. With the top-level VI select File->Save As...
  2. In the dialog select the Duplicate hierarchy to a new location option.
  3. Click Continue...
  4. In the dialog click the button "New LLB"
  5. Name your LLB.
(2,830 Views)
I'm on the phone with NI; the problem is deeper than that. The finder shows a vi as some sort of text file, even though it runs as a vi.
(2,826 Views)
