displaying images with a menu ring
What i want is  a menu ring ring that can give a choice to run indivdual tests . Test A, test b , test c test d . The results of each test to be displayed seperately with text on each image showing from which test the image came from,
Iam attaching an file that iam trying to implement this on.
Thanks for your help.
(requirements labview 7.1 and vision assistant)
(2,969 Views)
Hi jihn,
At what you need help, to use the rind or to show the selected text in your picture? I recommend to use an Event Structure for the selection.
Mike
(2,950 Views)
I think you can use the Picture Ring for your appliction.
- Partha ( CLD until Oct 2027 🙂 )
(2,939 Views)
