Hey Daniel. So can you create a small VI with just the control and maybe a constant that replicates the behavior and attach that? This doesn't happen if you are using anything less than extended correct? I checked around and I found the following
link which seems to indicate that this is fixed in a later version, but if you don't have access to another version this doesn't help you very much.
Please repost with a small VI. Thanks!
Andy F.
