‎11-20-2021 08:46 PM
I want to display 3 warning light( with different color) in the same LED I can not figure it out. any suggestion thank you
Solved! Go to Solution.
‎11-20-2021 08:53 PM
An LED is a boolean, and thus has only two states (T or F).
Of course you can change the colors of these state with property nodes, which is a bit of a kludge.
A better solutions would be to use a colorbox (it can be made to look like an LED).
‎11-25-2021 06:07 PM
plz help me how i can display the following warning light
low temperature ===> yellow light
normal temperature===> green light
high temperature ===> red light
‎11-25-2021 06:26 PM
‎11-25-2021 06:42 PM
how ? should i use case structure ?? Thank you
‎11-26-2021 12:49 AM
Sorry, I cannot look at your VI because I don't have LabVIEW 2021 here. Consider "save for previous" to get more responses.
Why a case structure?? Yes, you could use one, but there are plenty of ways that don't need one and these solutions are probably more elegant.
Did you look at some of my examples in my earlier link?
‎11-30-2021 01:31 PM - edited ‎11-30-2021 01:32 PM
yes I did look at your examples but still not figure it out
‎11-30-2021 02:11 PM
As I said, do a "save for previous" so I can look at the VI.
(From the gigantic oversized picture you posted (please crop it to the interesting parts!!!) you need to continue with the basic tutorials because that code makes absolutely no sense. For example, you compare a red and a green diagram constant and these are never equal, right? So what's the point? Where do you define the loop rate? Why is there even a while loop because since the subVI is outside it will only run once once and then never again, so the values in the tunnels will never change.)
‎11-30-2021 02:31 PM
‎11-30-2021 06:18 PM
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
