06-10-2013 02:19 PM
Hello All,
I am using Labview to communicate with a Microchip PIC virtual serial port. Ocassionally the serial comms is lost. To recover the connection I open Device Manager then right click the faulty comm port then select disable ( a red cross appears on the icon). Next right click the port again and select enable. The port now communicates correctly again.
Is there a way to use System Exec to drive this behavior automatically once a fault occurs or some other method to drive DM using methods and properties?
Many Thanks
Chris
06-10-2013 03:28 PM
06-14-2013 05:13 AM
Thanks for that, I am surprised at how simple it is to use DevCon however I still dont understand why cant I detect when the serial port fails.
Excellent workaround though
