When one looks at the specifications for the USB6501, one notes that it cannot do hardware-timed output. Therefore, you can't use a waveform datatype to generate output with this card.
So, you will have to use software timing and a loop. Since you specify a pretty slow transfer rate (0.5sec), it should work fine.
Look at one of the examples that ships with LabVIEW to get you started. Click "Find Examples...Hardware Input and Output...DAQmx...Digital Generation...Write Dig Chan".
Of course, you only want one line. So when you specify your physical channel, only specify one line. Change the function inside the loop to "Single Channel...Single Sample...Boolean (1 line)". Now the function will accept a single boolean value.
You do a lot of screwing around with getting your data into the right format. That can be simplified a lot. See the attached picture. This is not complete code -- you will need to look at the example I mentioned -- but this picture and the example, combined, should tell you what you need to know.
Hope this helps get you started.
