did inverse tangent not support FXP
  I tryed to use tangent inverse with FXP but it does not work, is anybody have idea about why this happen?
SASA
Message 1 of 12
(1,797 Views)
Hi SASA;
it happens because trigonometric functions don't support FXP!?
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
Message 2 of 12
(1,794 Views)
HI GerdW,
  In did,
  so the solution for me is to use double or SGL
  i prefere SGL but results are a litle bit different in the fractional side when using SGL and FXP.
 i expected the Ksin to be
-299,055055
 (plz see the epicture).
SASA
Message 3 of 12
(1,779 Views)
Hi SASA,
is there a specific reason to use SGL instead of DBL on the cRIO9068?
Message 4 of 12
(1,772 Views)
Hi GerdW,
  We need more precision in computing Ksin,   what do you think ?
SASA
Message 5 of 12
(1,766 Views)
Hi Sasa,
my opinion: use DBL for calculations on the RT host. Use FXP for FPGA calculations.
Message 6 of 12
(1,762 Views)
Hi GerdW,
   yes, but as you see we do all computing  Vis in RT side and FXP in not supported for trigonometric fuctions
  Did you have any idea about the NI9375 module, they say that it need external power supply but i did not found wher to connect it in the module?
  Best Regards,
SASA
Message 7 of 12
(1,754 Views)
Hi SASA,
the manual for the NI9375 explains all in/out pins and the needed connections. It also contains schematics…
Message 8 of 12
(1,746 Views)
Then use DBL, just like GerdW said to.
GCentral
Message 9 of 12
(1,696 Views)
here is the vi there is a difference and pictures, there are differences
Message 10 of 12
(1,684 Views)
