determinism in the host computer
Hi there,
I want to determine if my programe on the host is deterministic. The thing is that when I use the benchmarking technique and execute the code, the time is variable. How can I fix this?
Thanks in advance.
Cheers, Iñigo.
Message 1 of 9
(3,696 Views)
@IñigoP wrote:
Hi there,
Thanks in advance.
Cheers, Iñigo.
I suspect that the variance should already tell you something about determinism on your computer?
Bill
CLD
(Mid-Level minion.)
Message 2 of 9
(3,695 Views)
Well, if you posted the code (meaning something we could examine and, optionally, execute), we might be able to help you answer that question.  What do you mean by "deterministic"?  I presume you are running it on a Windows PC, which "allows" code to run according to its scheduling algorithm (oops, time for a Virus scan, oops, check if Adobe software needs to be updated, etc.).  Your code might also have "non-determinism" built into it -- does it do I/O, for example?
Message 3 of 9
(3,671 Views)
Is it possible to achieve determinism on a windows PC? I have a programme, but when I'm trying to benchmark it, I obtain an overflow on the counter (the maximum value for an U32). What can it be?
Thank you.
Cheers, Iñigo.
Message 4 of 9
(3,668 Views)
Determinism is also relative. Loop cycle times of a few seconds with a simple loop can be sort of deterministic in Windows.
Best way to measure the determinism is to use another device to time it. If you have a daq connected you can for instance trigger a digital output and measure it with an oscilloscope.
Message 5 of 9
(3,663 Views)
First of all better to show your code/example of your problem.
Now It is very difficult (impossible?) to say, why your counter is overflow
Message 6 of 9
(3,663 Views)
Here you have the program. You can see that the 2 ways I use to benchmark show different times, maybe I'm doing it wrong... I don't know...
Message 7 of 9
(3,648 Views)
Accepted by IñigoP
yes, both wrong. In both cases, you subtract a larger value from the smaller
see correct
Message 8 of 9
(3,641 Views)
ooh..... I see it know!! Thank you so much!
Message 9 of 9
(3,635 Views)
