determining where controls are used
I know that if you select a control on the VI's front panel and select find terminal, you'll see where this control is used in the block diagram.  I think I know the answer to this, but is there a way to know where this control is used/referenced elsewhere (in other VIs within your project)?  I'm assuming the answer is no.   Is there a way then to search for all occurrances of a type of control (i.e. 'where are tab controls used in my project?).
(3,289 Views)
If you right click the control and go to find (in LV 8.0) and select say property nodes or references (assuming you have those) or terminals and it should pop up the Search Results window that shows you where all of those occur, in the current VI.
If you want to search for this in other VIs, click on the find button in the Search Results pop up window.  You can then search for text or objest, select under Search Scope <All VIs in Application Instance> or a specified vi, and under include, check Hierarchy Window.  If you check the vi.llb, you will get everything that is included in the National Instruments vis as well (and a lot of password protected files).
Now, you cant specify a property node for a specific control or indicator (that I know of), you can just select property node (under Select object) and it finds all the property nodes that you created in your vis.
Kenny
Kenny
(3,285 Views)
