07-17-2013 10:18 PM
hi member
i try to detect reangle in binary image using shape detetion vi but no result i get
as you can see from figure below
i change many paramter <::max,min,
can any help please
best regards
Solved! Go to Solution.
07-18-2013 12:49 AM
Please provide the image that you are working on.
Also there are other options which are suitable for detecting rectangle like shape detection, Pattern Matching..etc..
07-18-2013 08:08 AM - edited 07-18-2013 08:11 AM
dear this is the image
note the rectangle size is change so i think pattren maching will not work
07-18-2013 03:55 PM
Hello Mangood,
There are LabVIEW examples that are similar to this issue that can assist you in developing your application.
Goto: Help » Find Examples » Browse » Toolkits and Modules » Vision » Functions » Geometric Matching Example
This examples parameters can be tailored to rotation, scale, and occlusion.
07-18-2013 05:15 PM
ok it work
but how can i get ROI value so can i get the each mached object and analysis it and find its area in pixel???
07-30-2013 08:56 AM
Hello Mangood,
The output cluster of IMAQ Match Geometric Pattern 2 has the position of the origin of each of the pattern matches. You can then use the caliper function to measure the height and width of the rectangle and solve for the area.
