delay of a signal
Greetings !
i would like to know how to apply delay for a time varying signal ?? where the delay we are desired to provide should be controllable, i tried using get waveform and build waveform icons but the delayed version has not obtained as result .! i thought timestamp t0 can give me some delay but how to use t0 to meet my needs is what my confusion !!
(2,678 Views)
Sorry, it's still not clear to me what you want to achieve.
If you have two captured waveforms and you want to display both, but one shifted, changing the t0 value is the easy method.
Just make shure that the 'ignore timestamp' property of the graph you use for the display  isn't set true;)
Greetings from Germany
Henrik
LV since v3.1
(2,607 Views)
