06-01-2009 12:42 PM
Hi Folks,
I'm surprised that I haven't found a VI to convert degrees to radians. I see an example in this forum that shows one, but its a screenshot and not the code.
Can anyone point me at that VI?
Roger
Solved! Go to Solution.
06-01-2009 12:51 PM
You'd have to point to that link so we know what you are talking about.
But if you have degrees, just divide by 180, multiply by pi, then you have radians.
06-01-2009 01:54 PM - edited 06-01-2009 01:54 PM
Depending on your application, you can use indcators with units or a simple math transform.
06-01-2009 02:01 PM - edited 06-01-2009 02:01 PM
You can also convert a pure number to a physcal number, convert to new units, then convert back to a pure number. 😉
06-01-2009 02:11 PM
Neat trick Altenbach! I could never figure out that convert unit vi, with your example it just clicked! Thanks!
06-01-2009 02:48 PM
Thanks for the quick reply!
I guess I'm not the brightest bulb in the universe. I only see the diagram as a graphic. where did you get the unit conversion VI?
sorry, for my density,
Roger
06-01-2009 02:52 PM - edited 06-01-2009 02:54 PM
I am not sure if I would take the detour over physical units, but it's all there in the palettes:
06-01-2009 02:58 PM
Ahh,
Thanks to all!
I was sure there had to be a VI to do this. I didn't want to reinvent one and have another developer call me on it. Thanks for helping me do my homework in advance!
Roger
06-01-2009 03:02 PM
Also, before you start using units, you should familiarize yourself with some of the details, because it can be somewhat confusing.
A good read is this old thread. (To see if you really understand, try to predict the result of the VI attached here, see picture). 😄
