dc servo motor control using pci7354 and umi box 7774
my project dc servo motor control xy table. position control.
i want to use voltage from analog output and triangle wave for make pwm signal.
in MAX at default 7350 setting  axis configuration i select type servo external commutation.
i/o usage output is DAC output and Feedback is encoder 1.
in this i learn from one axis move (accel-max velocity-decel).vi in ni example finder.
my question
1. in my understanding when i set up value (accel,decel,velocity max,target position) motion card will make varies voltage. isn't it ?
     i want to use this dc voltage from analog output for make pwm.
2. at default 7350 setting in MAX i select type servo external commutation when i simulate block diagram with 1-D interactive in MAX it's not work.why is it?
3.
(2,516 Views)
Hi supersputnikk,
I noticed that you also posted this questions here.  Lets focus on that post.
Kira T
(2,499 Views)
