08-23-2012 08:21 AM
I have a DAQ instrument that face a problem that the data stream length of each channel is different randomly , but it will put "0" value to compensate the difference ,the data are all stored .
I am not sure that whether is the hardware issue or LabVIEW program issue, if is the LabVIEW issue ,how to deal with it ? thanks !
08-26-2012 09:52 AM - edited 08-26-2012 09:54 AM
I just attach the VI for you to check , this vi is only for one channel . if you have several channels ,you have to create several this VIs for getting data .
if you create several channels , the data count is different between each channel at the same time , the sample rate is same for each channel .
how can i resolve this issue ?
08-26-2012 11:54 AM
08-26-2012 10:25 PM
thanks !
yes, it's not NI hardware. the vendor don't have the VI driver for the multi-channel ,only have the one channel VI driver.
i attach the VI , and if i want to solve this issue, shall i write a multi-channel labview driver ?
