‎03-30-2006 11:19 PM
‎03-31-2006 05:30 PM
‎04-03-2006 04:16 PM
‎04-04-2006 06:34 PM
‎04-25-2006 03:35 PM
Thanks a lot Matt.
I got the file & changed it to read continuously!
The problem is, the delay between the consecutive readings (of the three parameters) is about 1.6seconds! Which is real slow for my purpose!
Do you think it is a problem with the apparatus or with the way I wrote the code?
I have experimented a lot with it... it seems more to be a problem with the reading three numbers from lockin, so the delay is tripled (from 500 ms to ~1.6second)! When I reduce the timeout setting, it reads faster but it reads only zeros (i.e. non-sense)!
Any help/ideas will be most appreciated!
Ashutosh.
‎04-25-2006 04:04 PM
‎04-25-2006 10:49 PM
