daq with Caen qdc and tdc
Hi ,
I am trying to make a simple DAQ system with a CAEN QDC (V965A) and a CAEN TDC (V775N) in a VME crate that are controlled by a VXI card as slot_0 controller and a MXI-2 bus to a PXI card in a pc running LabView 8.2.
I need to write  the daq code in LabView as I have used it in the past for a similar configuration. I need some help with a direction to posted occurrences of this  type of code even if it is for slightly different modules (adc or tdc). I try not to have to write the code again from scratch as time is of the essence. I am sure someone has that working daq system within the past five years. These setups are very popular in nuclear physics experiments. Thanks.
"Expert is the man that has made all possible mistakes in his field"
(3,561 Views)
Hi Athans,
I would recommend asking Caen, if they have any LabVIEW drivers or even C drivers.
I have seen there are some LabVIEW drivers for some of Caen's products so this should hopefully bear fruit.
Regards
JamesC
NIUK and Ireland
(3,541 Views)
