06-10-2010 01:21 AM
Hello!
I work with CwGraph3D an LabView. I like to have an event when the cursor on graph changed the position. Is possible to do this?
Thank for a help!
Solved! Go to Solution.
06-10-2010 02:34 PM - edited 06-10-2010 02:34 PM
Hello Toni2,
What control exactly are you using? Can you post your example VI with the graph control?
Sebastian
06-10-2010 02:43 PM
skoziatek wrote:Hello Toni2,
Sebastian
Message Edited by skoziatek on 06-10-2010 02:34 PM
[Be gentle Ben ! ]
A "CwGraph3D " is a Component Works 3D graph.
You can find an LV example that uses the CW 3D graph in this thread.
The CW 3D graph ships with LV and if not written by NI, the rights to it are NI's.
Toni2,
I don't think you can register for a cursor move event. I suspect you will have to poll but I'll leave that for the NI Experts to settle.
Ben
06-10-2010 02:54 PM
Weird - I just experienced what I thought was deja vu when I thought I remembered the same thread you started before about this control. Turns out you DID start a thread, but a different aspect of the same control.
I need a nap.
06-10-2010 03:32 PM
What if you use ActiveX Register Event Callback? I have found that you could register for event CursorChange (attachment screenshot).
06-11-2010 01:52 AM
06-11-2010 02:25 AM
I can run the program, but i'dont now how to see the event in case of cursor changed. Can you add this part of code to?
Best regards!
06-11-2010 02:54 AM
06-11-2010 03:02 AM
