custom define the active area for a toggle switch?
Is there a way to increase and custom define the active area for a toggle switch? I don't want to make the switch bigger, I just make it so you don't have to click precisely on it and can just get close.
(3,118 Views)
Earlier today I posted a question about the boolean text on a toggle. The reply from JB helped me and gave me a hint as to your question.
If you show the Boolean text, the boundaries of the text box appear to become the sensitive area for clicking on the switch. The switch attached shows this. I colored the background of the text box to make it easy to see the boundary.
Lynn
(3,106 Views)
Hi Mosey,
you can customize it. right click on your control and select -> advanced -> customize. If you resize the circle, then the area should be bigger.
Mike
(3,102 Views)
I did not know that.... thanks Lynn, I'm sure I'll find a use for that down the road. Smiley Happy
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(3,094 Views)
SteveA,
I did not know it either until I was trying to do something else with customizing a control this morning and happened to notice that it had this effect.
Lyy
(3,073 Views)
Lynn, Thanks for the help. I have it working good now.
A few helpful tips for anyone who may use this:
After you right click on the switch and select Advanced - Customize, you need to Change to Customize Mode (click on the wrench).
If you have any text in the area, make sure you move it to the back (Ctrl+Shift+J, or click on Reorder from the top toolbar) or you will have a dead spot where the text is.
Don't forget to save it as a Strict Type Def so you can reuse it.
(3,060 Views)
