05-03-2011 02:13 PM
Hi community,
I have a pxi-realtime-system that logs automatically multicast events from our network and creates a log file that becomes larger every minute.
The file is named packetsIn.log and appears under /ni-rt/system/ethernet.
The content of the file is
Source Mac: ...
Dest Mac: ...
PacketSize: ...
The mac-adresses that appear in the file are not the one of my controller but of some switches or multicast-adresses in our network.
If you delete the file, it appears again some seconds after that action. The file also grows, if no labview-application is running on the system.
Has anyone noticed a similar behaviour? What could cause this file-creation?
We're using LabVIEW 2009 SP1 and the curious is, that it only appears at one of our controllers.
Hope someone could help
gibbi
Solved! Go to Solution.
05-10-2011 04:28 AM
Hi Gibbi,
please try to open the ni-rt.ini and set following entry:
[DEBUG]
RTPacketParsingEnbled=FALSE
After that the file should stop growing.
Best Regards,
Lam
