04-10-2015 10:49 AM
Hello!
i try to speech recognizer ( Wind XP sp3), but have a problem :
error : "The language for the grammar does not match the language of the speech recognizer.".
i see this example:
https://decibel.ni.com/content/docs/DOC-4477
but cant find a constructor GrammarBuilder culture to "en-US" in Vi.
Where is it, and how to create it?
Thanks!
04-13-2015 10:24 AM
Hi Black1,
Looking at the example that you sited in your post if you open up the block diagram for Speech Recognizer Initialize.VI you will see the Grammar Builder constructor. You can then right click on the output and select create -> Property Node -> Culture. You can then change Culture to write, and right click on the input create -> Property Node -> Name.
