crystal reports
Yes,
The Connection works fine.
I'll check the parameters.
Thks.
Message 21 of 34
(2,355 Views)
I've been doing some test, the CR display is correct.
I still can't change Database Connection (Although what I can save withprogramming in SQL).
Now I have a problem with the print option.
If I enable the printer option, the CRViwer button displays the printer ok(but no action). If after viewing the effort report programmatically print, it presents acatastrophic error.
Zoom methods and save work properly.
Message 22 of 34
(2,342 Views)
Don't use the embedded print control, it gave problems to me also. there is some race when using it, maybe the report is not ready yet from CR engine.
Try to use an external one. Keep the data flow as in picture, this should work.
Message 23 of 34
(2,332 Views)
Thanks.
I'll try it.
I have been working on the recovery of an old LLB.
It has many features, creating a programatically report.
Here is the link. I still haven't tried it in depth, but is updated to be operational in CR11 versions,  including some of your contributions.
Message 24 of 34
(2,327 Views)
i developed a CR print.vi
i have problem, i excute the vi but no action.
Does any one guide me??
Message 25 of 34
(1,992 Views)
Is it possible for you to post your code on this forum so that I can look into it further? Also, what exactly happens when you run the vi? Do you get an error?
Message 26 of 34
(1,951 Views)
The printer "doPDF 8"  may not be correct.
Try to set the input from the reportsource  unlinked with OpenReport.
Try the llb of the previous post.
Message 27 of 34
(1,943 Views)
thx for ur reply
Shreyas.U :the vi run without error!!
Dirizabal: i tried but i still have the same problem!!
Message 28 of 34
(1,931 Views)
hello Dirizabal,
i can't found print vi in the llb, can u send me ur code please??
Message 29 of 34
(1,915 Views)
hello Marco_Ge
i need your help,
Can u correct my code or send me ur code CR print!!!
Message 30 of 34
(1,875 Views)
