crystal reports labview active x
Does anyone have an idea on how to open a crystal reports report from labview? I am working on an application where test measurement data is stored from labview in a SQL database and I need to open several crystal reports from the same labview app. I have labview 8.5 and crystal 8.5.
Thanks in advance
Message 1 of 8
(6,367 Views)
Any ideas????
Message 2 of 8
(6,346 Views)
Accepted by topic author Jaime Rodriguez
If CR has registered an activeX i s'pose you can do it like i did with Acrobat.
Place an activeX container on front panel, link it to CR's activeX.
 Place Invoke Nodes and use what functions are needed.
I assume you'll need some Load file, view/render, Close.
I hope that helps.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 8
(6,335 Views)
Thanks a million that is exactly what I did... Add an ActiveX container in the front panel and add Crystal Reports Control to it, then play around with the property and invoke nodes.
Message 4 of 8
(6,323 Views)
Question: How did you convert a path e.g. c:\test.rpt to a suitable variant for ReportSource?
Thanks.
Message 5 of 8
(6,154 Views)
You can use the variant to data function and convert it to any data type... However, I used the Crystal Reports Control ocx not the crystal reports viewer.... This one has a string input for the report path..
Message 6 of 8
(6,141 Views)
I am trying to do something similar with lab view and crystal report but I am not familiar with activex. is it possible to have an example of how you did your code to control the report generation, that would be highly appreciated, Thank!
Message 7 of 8
(4,780 Views)
Try this example that ships with LabVIEW to get you started with ActiveX. In LabVIEW go to help > Find Examples. Then in NI Example Finder browse to Communicating with External Applications > ActiveX > General > ActiveX Event Callback.vi
Aaron Douglass
Message 8 of 8
(4,757 Views)
