03-28-2007 12:09 PM
03-28-2007 02:29 PM
03-28-2007 06:05 PM
03-28-2007 06:06 PM
03-29-2007 10:04 AM
03-29-2007 11:05 AM
03-29-2007 11:57 AM
03-29-2007 02:46 PM
03-30-2007 09:22 AM - edited 03-30-2007 09:22 AM
I gather from what you have written that you have run into a couple of issues but mainly that your host PC cannot connect to the 9004 controller via MAX? I also understand that someone else may have been using the controller before you. Essentially before you download your VI’s etc onto the 9004 controller from your host machine you need to ensure that the driver software versions on the 9004 controller match up with the driver versions on your host machine.
In a KB that is currently being processed I wrote:
Although my cRIO device is detected in MAX under remote systems I am not able to upload software drivers on to it. In other word when I goto MAX > Remote Systems > right click software directory that resides under cRIO device, then MAX will give me VISA error message; error 59.
In the cRIO operating instructions manual it states under the heading, For Safe Mode Switch section: “Push the safe mode switch to the ON position if the software on the controller is corrupted. If there is no software installed on the controller, the controller automatically boots into SAFE MODE regardless of the position of the SAFE MODE switch. The SAFE MODE switch must be in the ON position to reformat the drive on the controller.” Thus one must not forget to “reformat” the drive before attempting to upload software drivers. When the system boots in Safe Mode, it’s just loading a minimum set of drivers (from an onboard non-volatile memory) required for the controller so you can find the controller in MAX, set the IP address and install software. Software like NI VISA or NI-RIO is not loaded in memory. This would be one reason why you would not be able to target the controller from LabVIEW or open VISA session from MAX. You can reformat the memory on the cRIO by right clicking on it in MAX and selecting Format Disk from the shortcut menu. The controller will still be in safe mode (no software installed) but you will be able to install software from MAX.
Reformatting the Internal CompactFlash Memory on NI Real-Time Controllers
http://digital.ni.com/public.nsf/websearch/6D0F9F74FD2DAD0186256EE5007198D4?OpenDocument
Also can you please tell me the driver versions that you have got installed on your machine? There is a known issue with MAX 4.2 shipped with feb 2007 driver cd. The problem affects MAX’s ability to display RT targets under remote systems in certain instances.
Ideally its best to exhaust all avenues before concluding that the device is in need of repair to save you having to go through the process sending it back to us only to discover that there is nothing faulty with the device.
I hope this helps!
Kind Regards,
Kirtesh Mistry
Message Edited by Kurt NI AE on 03-30-2007 09:23 AM
Message Edited by Kurt NI AE on 03-30-2007 09:24 AM
03-30-2007 09:41 AM
@Jzee wrote:
hmmm.... there was someone who used this cRIO before i got it and he had his software on it. when i got it i was able to connect to it. i didn't download any software of mine on it. I ran couple of examples on my computer using the emulator option but never downloaded anything on it. and i assume that the guy's software is still there because he had two digital outputs to motors and the LEDS for these are still ON exactly the same way as i got the cRIO $which means his software is still there. i.e, i didn't change anything 😞
such a bad timing really, do you have any idea how long does NI normally take to return products back?
thanks for your help ... really appreciate it.
