Open the VI project\install.llb\Install Build Installer.vi. This VI is automatically called by the builder to create installation files.
You can put this VI on "Pause" to allow you to modify the executable before the installer bundles the files for installation and resume execution thereafter.
You can also simply let its FP open, let it run as usual and rerun it with the same FP controls values after your modifications are done.
