create holes in 3d objects
Is it possible to create a solid box with a hole that goes completely through it and one that goes halfway through it? I have been unable to modifie the internal contours of objects. Is this even possible or do I need to use third party software embedded in my application?
(3,199 Views)
maybe one possibility for the 'hole ' is to fill the z matrix with Nan where you want the "hole" points..
N
(3,171 Views)
I'm not really sure what you mean. Can you provide an example of it?
(3,161 Views)
hi
just try to put Nan in the Z value  you want to plot.
N
(3,144 Views)
More often that not, the 3D images themselves are created in an external environment and then manipulated (rotated, for example) within the 3D Picture Control. I would recommend going this route if you are planning to just view an exisiting image in the 3D Picture Control.
Vivek Nath
Machine Vision
(3,124 Views)
