create an interop assembly for .NET 3.5 with LAbVIEW 2013
Hello folks,
I want to know, if it is possible to create a .NET assembly for .NET 3.5 with LabVIEW 2013. According to the LV help, LabVIEW uses .NET 4.0.
One of our customers asked for an application with an .NET interface. For testing purposes I created a small application and a .NET assembly to call the small application. At my local machine all worked well.
But the customer now complains about the .NET version. He is using .NET 3.5 and so can not play and test with my test app.
One possible solution would be go back to LV2011. But I would prefer to use LV2013.
Regards
Heinrich Eidloth
(3,675 Views)
Dear Heinrich-Hans,
you can force LabVIEW 2013 to create interop assemblies in a lower .NET Version by editing the labview.ini . This is described in this article:
http://digital.ni.com/public.nsf/allkb/1BAA896E8E51E1BD86257B6A0055F200?OpenDocument
Best regards
AndGar
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(3,638 Views)
Dear Angard,
thank you for your answer and the link. I have just tested it, and it is working.
Best Regards
Heinrich-Hans
(3,621 Views)
Could you explain me how to change the .ini? ... the link above is not available,
Thanks in advance.
(3,094 Views)
