counter reseting after particular number is reached
I need a counter which will count from 1 to 20. It should reset at 20 and again start from 1 again. Can any one help me in this.
Also I need how to interface the labview simulation with real time clock. I mean span of 1 iteration in my simulation should be 1 second.
Thanks.
(3,070 Views)
Hi, here is how I would do the count:
Regarding the real time clock, do you mean a physical hardware called so?
(3,059 Views)
The Remainder function is your friend, as is the Feedback node.  Each time this piece of code is called, it will report the next higher count.  Make it a sub-VI called "Count 1 to 20" with the Count 1 to 20 as its output and you are done.
P.S. -- I really didn't "get" Feedback Nodes, and still don't use them very often, but for something like this, they are ideal!
Thanks.
(3,020 Views)
In a normal application, use the Quotient & Remainder.  It is the easiest code to understand.  When going to FPGA, do the normal comparison and a Select function.  The Q&R is really expensive in an FPGA.
(3,010 Views)
