12-27-2014 02:51 PM
hi , can help and joint me attachement of core 1 and core 2 exercice v 8.5
12-27-2014 03:03 PM
Are you asking if anyone saved the exercise files from ten years ago and can attach them to the forum?
I'm going to bet that in the rare event someone still has those, they'd be too large for the forums to host.
Do you have the manual? If so, you should be able to put most of the examples together without having the VIs.
12-27-2014 03:10 PM
i have the vis but problem that's not the same version of 8.5
12-27-2014 04:34 PM
12-27-2014 11:29 PM
If you're using a version of the core classes that has newer VIs, keep in mind the course likely will have things that aren't consistent with 8.5. Expect to run into that as you go through the course
