06-03-2011 09:11 AM
Hi All,
I have a system set up which records the inputs from 12 9236 modules through 2 cRIO chasis in FPGA mode. I am now in a position where I want to analyse the data, at the moment I have got the data in front of me in it's raw format. The trouble is I am not 100% sure what these numbers actually represent!!!!!! Do they represent Voltage values or something else?
The module is configured to return calibrated results (ie calibration mode: Calibrated) I guess this is merely tells the unit whether the module has been calibrated or not?
I have attached an output for my strain gauges and accelerometers (They need converting as well!)
06-03-2011 09:25 AM
I've attached the actual vi, and one of my many data files for you guys to play with.
06-03-2011 09:43 AM
NOTE:
The data is not in an xls file, I just had to rename it so it would allow me to upload it!!!
Don't try adn open it in excel!
