convert pwm to voltage
Hi, I'm okky
Can I convert PWM to voltage using analog output in NI-USB 6009 ?
I will be happy if you suggest example to me
regard
okky
(4,411 Views)
The 6009 is a software timed device.  You're going to have a hard time doing much of anything with it and pwm.
But, here's a starting point: https://decibel.ni.com/content/docs/DOC-2066
I trust you can handle an AO task on your own or with the example finder
(4,391 Views)
what is the function of this vi ?
(4,384 Views)
"This vi converts a sine wave into a PWM signal and then demodulates that signal back into a sign wave."
(4,357 Views)
Try measuring your PWM with Pulse Measurements VI. One of the outputs of this VI is duty cycle. Depending on the output from 0-100% duty cycle you can drive the analog out of your 6009. Multiply 0-100% by .05 and 0-100 will convert to 0-5V.
PaulG.
Retired
(4,336 Views)
can you suggest to me some example with pulse measurement vi. because I'm beginner in this LV
regard
okky
(4,300 Views)
We were all beginners at some point, here is some free training if you are interested.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
You can search the Help >> Example finder, I assume there is some example on tone measurement.  Are you able to get the data using DAQmx or DAQ Assistant?  As mentioned earlier your device will have a hard time getting analog data fast enough.
(4,274 Views)
