convert mouse position to image position
Using a zoomed IMAQ image in an image control, I want to recover the position of the mouse in the co-ords of the underlying image. LastMousePositionX (and Y) give the info I want but they are one click in the past and not the current position. Amazingly, there doesn't appear to be an equivalent CurrentMousePositionX. I can't seem to find the info I need to do the conversion manually. The mousedown event returns the current mouse position and I can get the position in the image container by subtracting off its left and top position. But to convert this to the image position I need to know both the zoom and where the images origin is relative to what is displayed. I can't seem to find that origin position in the list of property nodes. The only thing I can seem to come up with is to extract the info from teh image information string, but this seems like an incredibly poor way to extract such obvious information - espeically since the info must be calculated to put in the string anyway. Can anyone help with this?
Message 1 of 9
(7,689 Views)
I don't know about the IMAQ image control, but the 2D Picture control has a Mouse property, which gives the current X and Y position of the mouse. Could you place a transparent Picture on top of your image control and use the coordinates that way?
Robot Happy
Certified Developer
Message 2 of 9
(7,677 Views)
CurrentX and Y work if the whole image is displayed. I've used that before. The advantage (and problem) of the image control is tha you can zoom and pan arbitrarily. The CurrentX and Y give you position in the window. To convert that to co-rods in the image you need both zoom and the location of the origin of the IMAQ image relative to the origin of the image control. I don't know how to get that last piece of info.
Message 3 of 9
(7,669 Views)
I am confused why you get the mouse position one click in the past because it seems to work ok for me. I've had to use four of the image properties to recreate the effect using the mousemove event, but this seems to give the same values as the Last Mouse Position property so I think it does what you want. I couldn't see an origin property so I did the conversion using the position given at the image center. I wanted to post a snippet here but I'm new to posting and couldn't seem to get it to work for the whole block diagram, so I'm using a screenshot instead. I hope this helps in some way.
Will
Message 4 of 9
(7,648 Views)
@Polyphemus wrote:
[...] get the mouse position one click in the past [...]
To avoid this time-lag I guess you are supposed to force the event structure do run once, without a user triggered event; therefore you can use the property node "value" and "value signalling (SGL)"
in the time-out frame of the event structure
Unfortunately I can't test this with your code as I don't have IMAQ on this PC.
Message 5 of 9
(7,641 Views)
I suspect that because you are using mouse move, which is constantly updating, last mouse position works reasonably well. I'm using mouse down, as I only want things to happen when I click and last mouse position definitely gives me where the mouse was when I last clicked. I'm marking a grid and it is definitely the previous grid point that last mouse position returns. On the plus side, image centre does seem to return the point of the larger underlying image at the display centre, so using that I could figure out where in the larger image I'm working. That's somewhat nicer than getting the co-ords from the image information string and converting them, which is what I was reduced to doing. I still don't see why there isn't a current mouse position feature that gives co-ords in terms of the underlying image as last mouse position does.
Another little item that isn't clear to me is why the underlying IMAQ image lists mouse operations under its events. They don't fire when you are working on the displayed image.
Finally, I discovered the hard way that the mouse events still fire even when you are over the ROI toolbox, so clicking to change a tool causes the mouse down event to fire. Dumb! Fortunately easy ro fix by checking whether the mouse is inside the dispaly area, but still dumb.
Message 6 of 9
(7,623 Views)
Robot Happy
"place a transparent Picture on top of your image control"but how?
Message 7 of 9
(7,493 Views)
hi,
I would do this:
1# right-click frontpanel>modern>graph>elements>2d picture
2# tools palette>brush-tool>transparent color
there's also this entry in the online-help
https://www.ni.com/docs/en-US/bundle/labview/page/creating-transparent-objects.html
Alex
Message 8 of 9
(7,461 Views)
Thanks for this code! It helped me understand what was going!
I used this code in my project and noticed it only works when I am zoomed in far enough. If I zoom out, and a part of the image becomes empty within the image area, the code does not work. While debugging I discovered that:
  • Image area: the entire area of the image control that can be used to display an image (fixed during runtime)
  • Displayed image: the image that is displayed inside the image area (can change during runtime based on the zoom factor)
Therefor, if you use the "Image Area Position" property the position will always return the same during runtime; the position of the image area with respect to the front panel origin. It is better to use "Displayed Image Position" which returns the position of the image with respect to the front panel origin. This also accounts for the situation in which the image is smaller than the image area and part of the image area is unused. When zoomed in far enough so the image fills the entire image area, both property nodes return the same value.
Message 9 of 9
(278 Views)
