convert labview 6.1 to 7.1
Can anybody convert this program written in 6.1 version to 7.1.
Is the subvi's required for this.
Message 1 of 8
(3,958 Views)
Accepted by topic author malavi
You should be able to just open it up in LV 7.1.
Did you have a problem when you tried?
Message 2 of 8
(3,938 Views)
In the VI properties, it is actually 7.1 and the OP wants to save it as 6.1 it seems.
Message 3 of 8
(3,935 Views)
When I open the program it shows the following screen.I just want to clarify whether it is version incompatibility.
Message 4 of 8
(3,934 Views)
So you have both 6.1 and 7.1 versions installed in the same PC?
Those are just warning messages. But try renaming or save it in a different location.
Message 5 of 8
(3,925 Views)
Did you read the messages?!
Basically, the files were loaded from the 7.1 location instead of the 6.1 location. Most likely these third party driver VIs exist in both versions on your computer and LabVIEW was smart enough to load it from the new location after you switched to 7.1. That's probably a good thing! :). Do you get any broken arrows?
Message 6 of 8
(3,924 Views)
No broken arrows when I open it.  If it is alright I think I can proceed to the next step of the program. Thanks to all.
Posting the task as new post.
Message 7 of 8
(3,920 Views)
I think now I can close this post and mark it solved since no further processing required relating to the subject.
Message 8 of 8
(3,919 Views)
