convert from 8.2.1 to 7.1
Since Robbob thought it would be better to start a new thread this is what I did (I think!).
I ask if someone with LV 8.0 installed could do me the favor of converting these simple VIs to LV 7.1.
If Copy and Paste worked between different versions, even just for the simple things, that would be enough for me - but I tried and it doesn't...
Paulo Lobo
(3,261 Views)
Accepted by pmasl
It appears you forgot "Format String.vi" I've converted all the others but it will only work if you have the format string vi saved in 7.1 or earlier, if you don't please upload that so it too can be converted.
(3,252 Views)
That laser_protocol VI really needs to have ALL of the local variables deleted.
(3,246 Views)
Thanks. This was a really fast and effective reply.
I left out "Format String.vi" because there is a limit of three attachments. Being the simplest of the four, I thought I would do it manually.
If it isn't too much trouble, please convert it as well, since I haven't yet begun to integrate these VIs into the old program.
Paulo Lobo
(3,219 Views)
