conver exe to vi
Can i convert .exe to .vi file in LabVIEW..I want to know solution of this..
Message 1 of 16
(7,174 Views)
Accepted by topic author krunal.parmar03
Hello kunal,
no that is not possible. I someone creates an exe, you can't recreate a vi out of it.
One of the reasons is to save the programmer's code from being copied.
It is also not possible recompiling C-Code and similar, for your information.
Regards
Message 2 of 16
(7,161 Views)
That's usually impossible.
However if the .exe was built with the block diagrams embedded (which is not the default), then it is possible to extract the VIs from a .exe.
Message 3 of 16
(7,136 Views)
How can you find out if the block diagrams are emedded in the .exe?
Message 4 of 16
(7,105 Views)
I don't remember.  Try my old VI extractor.  I wrote it in LV 10.  Probably still works.
Message 5 of 16
(7,094 Views)
thanks...i will try and chech whethe it work or not...
Message 6 of 16
(7,075 Views)
Its not possible,
See the example,
In the exe if you have output 9 then it can be from 0+9,1+8,2+7,3+6,4+5. Then finding which is input is tough job.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 7 of 16
(7,048 Views)
@Ranjeet_Singh wrote:
Its not possible,
See the example,
Gibberish?
Message 8 of 16
(7,031 Views)
no output
Message 9 of 16
(7,011 Views)
Why do you want to do this?
If it was created with an older version, typically all you could do was get a list of VIs. The exe was basically an llb. You could rename it and open it with LabVIEW. You could not see the block diagrams because they were almost always removed by the creator of the exe. I would recommend you give up trying.
Message 10 of 16
(7,006 Views)
