06-22-2015 12:02 PM
I want to make controls on the front panel to appear. So, say the front panel has two visible controls A and B. If the user makes A true, then another control, X, appears and the user can make that true or false. If the user makes B true, then Y appears, and the user can make Y true or false. How would I go about in doing something like this?
Thank you
06-22-2015 12:08 PM
06-22-2015 12:19 PM - edited 06-22-2015 12:20 PM
Thank you for your answer,
However, could you be a but more specific about the visible property and how I would incorporate it into my block diagram? I understand how to create the property, but I do not know how to use it in the block diagram to do what I want it to do.
06-22-2015 12:22 PM
06-23-2015 07:09 AM
So, what I am doing is I have a menu ring as a control on the front panel. If option 0 (value) is selected, I want a bunch of other controls to become visible. If option 1 (value) is selected, I want a bunch of other controls to become visible. I am trying this with a case structure but I cannot seem to get the controls to be invisible. Is their an invoke or create invisible property by default?
06-23-2015 07:28 AM
Yes. Right click on the control. Create property node. Find the "Visible" property.
06-23-2015 07:35 AM
I get the visible property. It is clearly visible even without the visible property. What I want is invisible. I want it to become visible when the menu ring is selected.
Everything is visible I don't want everything to be visible when starting. I want it to be "Invisible"
06-23-2015 08:03 AM
06-23-2015 08:38 AM
Pretend that you work for IBM, whose motto is "Think". You can also pretend that you are a scientist and "do an experiment" -- write a tiny VI that has a control on the Front Panel. Create a property node for that control. Select any property. Wire a constant to that property. Run, see what happens. Now wire a different constant, run, observe. Make a deduction.
... and when all else fails, Read the **** Manual (or, in LabVIEW's case, right-click on the Visible Property Node and choose "Help for Visible").
06-23-2015 09:30 AM
Context Help is your friend. Turn it on with Control H.
